Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Torque Converter Flexplate Question
Old 03-02-2008, 06:10 AM
barnym17 barnym17 is offline
were you able to spin the convertor in the trans or did it bind on the flexplate before you bolted it up? If you could spin it that eliminates the convertor causing the starter problem.Would have to be flexplate or starter issue.As to the spacers I used them on my boys v8 s10 with a 700r4 after reading about it here worked great just used a couple washers between the convertor and plate.
