700r4 Torque converter recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2012, 07:30 PM
blacklabzeke's Avatar
Can anyone recommend a decent 700r4 lockup TC brand. I have had 2 Recons fail, one with a bad weld at the hub (fluid leak) and one with a faulty stator clutch and now a Dacco with a broken turbine hub all within 30k miles. I'm running a stock engine in a 1988 fulsize Blazer with minimal light towing and don't beat it. Original converter was code DEF with I believe 1650 stall and I would like to stay close to that for fuel economy. Any input would be greatly appreciated!
Old 10-28-2012, 05:59 AM
F-BIRD'88's Avatar
Yada Yada Yada
ATI Transmissions and converters
www.atiracingcom
Do you have a origional, usable, rebuildable torque converter core
they can use.?
Old 10-28-2012, 03:13 PM
No. Core for 1st replacement.
Old 10-28-2012, 06:29 PM
joshp83's Avatar
owner of Prices Garage
i use dacco in my shop i had no issues so far i was using recon in the shop i worked at before i had 3 failures in diffrent vehicals leaks vibration loss of movemnt in 3 diffrent vehicals i use a guy in cleveland ohio on custom builds perfect converters is his company as far as a hub break iv e neever seen a 700 do that culpe things to look at i seen this on chrysler units is pre ignition will do that also inspect the dowel pins and flex plate if u want a tad bit lower stall u can get a 1375 most diesels used that also a 97 carbon unit has a smoother lock up and will last longer any questions feel free to call me or pm ************ ******
Last edited by Crosley; 10-28-2012 at 08:25 PM. Reason: commercial advertising contact information
700r4 torque converter best47 Transmission - Rearend 2 01-07-2011 08:21 PM
I need a 700r4 converter stall recommendation dlisabeth Transmission - Rearend 9 06-09-2010 08:30 AM
700r4 Torque converter retiredmodman Transmission - Rearend 2 03-29-2009 10:14 PM
69 Camaro, Torque Converter Recommendation? FBody Transmission - Rearend 6 03-29-2009 05:49 PM
Torque Converter Recommendation tc33 Transmission - Rearend 2 03-20-2005 05:26 AM
