700r4 torque convertor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2005, 04:24 PM
USAF F-16 ELECTRICIAN
someone told me that a th350 torque convertor will fit on a 700r4 and you dont need the lockup wiring harness to make the trans work right. this sounds a little shady so i was just curious if it is true.
thanks in advance
Old 09-01-2005, 04:39 PM
ronb's Avatar
thanks in advance
sounds like that someone" is on crack?
Old 09-01-2005, 04:54 PM
well there are alot of people around here that think that they know everything and since i dont know i ask questions if it doesn't seem right.
Old 09-01-2005, 05:12 PM
ronb's Avatar
well then you are smarter than them!
Old 09-01-2005, 05:18 PM
so then i do need to hook up the lock up wiring harness. the engine isnt done yet so no biggie. im stillnot sure how to hook up the tv cable. when i bought the truck it had a 305 connected to the 700r4 now it has a 350 connected to it. the wiring harnes never was hooked up and it doesnt have the hookups for it. how hard or important is it to hook up the wiring for the lock up?
Old 09-01-2005, 05:37 PM
ronb's Avatar
Unless there were serious mods made to internals of that 700? the tv cable needs to be hooked up and adjusted properly! i assume you are using a carb? if you are you need to get the right tv bracket! the quad and holley carbs use different styles! either one can be purchased from TCI automotive as well as the wiring kit for the lockup converter! B&M also has a wiring kit! they sell for around $65 and include everything you need!
Old 09-01-2005, 05:59 PM
i appreciate your help. i am wondering how the hell i was able to drive it as long as i did. i always shifted it manually though so i dont know how much of a difference that makes. i could make the wiring harness myself if i had a diagram for it. save me 65 dollars i dont have.
thanks again for your help.
Old 09-01-2005, 06:04 PM
ronb's Avatar
yes you could make it yourself! but you will need a pressure switch to install in the 4th gear oil port and they are difficult to find alone but are included in the B&M kit
Old 09-01-2005, 06:08 PM
well guess i will look into buying that. oh well. what about getting the harness from the trans donor car. i was told it was a 91 caprice. but im guessing the harness is integrated in with all of the other ones.
Old 09-01-2005, 08:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
read this site twice: lockup ........ email questions to me
part number for the needed pressure switch is there too
Old 09-02-2005, 02:53 PM
ronb's Avatar
the harness out of the donor car will not do you any good if you are not using a computer(ecm)? the B&M wiring kit has everything you need! NOTE! the pressure switch in the B&M kit is different than the internal gm switch that is shown in the link crosley provided us as it is installed on the outside of the case in the 4th gear pressure port(has a double spade terminal). also if you can find a 1985 gm van at the local salvage yard with the T350c? this has almost and identical setup as the B&M kit! you can use the harness off this vehicle!
Old 09-02-2005, 06:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Trying to use an external pressure switch......the only problem that may come up is the pressure ports were deleted in the 1989 700 tranny cases.... it was a running delete. I've had 1989 cases with full pressure ports drilled and plugged, I've had 1989 cases with the bosses there with NO holes, and I've seen 1989 cases with NO boss for the ports at all.
Old 09-04-2005, 10:31 AM
ronb's Avatar
yup your right crosley! i have seen a few myself! the thing is thought will he be able to use the wiring schematic you provided and be able to manually unlock the lockup if needed for towing? the B&M kit includes a rocker switch for this option and you do not need to drop the pan to hook it up!
Old 09-06-2005, 01:28 PM
i really appreciate all the help. i am going to be going to michigan for a month to visit my family so i will have my dad look for one. it is alot easier to find stuff like that in michigan then it is in utah. that and i know quite a few guys that own trans shops and performance shops, so they can hook me up.
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Torque convertor advice Throttle Transmission - Rearend 1 05-03-2005 07:59 AM
700r4 torque converters-identification hueysrod Transmission - Rearend 3 03-14-2005 08:46 PM
th350 torque convertor installation MickiG13 Transmission - Rearend 2 11-07-2004 12:21 PM
opinions needed - Torque convertor issue badA31 Transmission - Rearend 15 11-24-2002 09:11 AM
