700r4 torque convertor flair - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2008, 02:15 PM
Installed new Bowtie O/d convertor for possible vibration problem - had slight flair( or slipping) on hills in o/d. replaced with new one and problem, is worse. Have Bowtie o/d kit and it worked perfectly on original convertor. Changed input shaft seal on last replacement. Shifts fine and have verified voltage to plug. In 36 Ford street rod with all Bowtie parts for trans. Any ideas would be appreciated.
Old 03-25-2008, 02:27 PM
700r4
Do you mean the transmission has, or had, a flair or slip, in overdrive?
Old 03-25-2008, 02:48 PM
engine will flair 200-300 rpm's only when in lockup mode. I wired a switch in the lock up circuit to switch off the lockup and never has engine flair - shifts to 4th and works ok. . When in lockup- engine rpm will flar up a couple hundred PRM's then catch and relock up then do it again. thanks for the reply
Old 03-25-2008, 04:00 PM
If your running all the GM sensors and computer in the circuit, this is normal. When in OD and loaded up so the engine is working as opposed to loafing along, it should come out of lock up and perhaps OD depending on data it's getting.
If there is no computer in the circuit and the lock up is switched manually on or off, as the tranny sees more load on the output end and is trapped against a locked converter on the other end, 4th will slip.
Bogie
Old 03-25-2008, 04:22 PM
Bogie -- ther is no computer in the circuit- your thinking that it might be actual 4th gear slipping a few hundred RPM's than catch up and start to slip again?
As always - thanks for the info
Old 03-25-2008, 04:40 PM
I keep forgetting the 700R4 is a mechanically controlled 4L60E which I'm more familiar with. However, I'm expecting that as load goes up it's hunting between 4th and 3rd and back. This might be as simple as a TV cable adjustment.
Bogie
How do threadf lubes affect torque values? jonathanks Engine 11 05-12-2014 07:00 PM
Will a 700R4 withstand BBC 500+ lb-ft of Torque? Malibu73 Transmission - Rearend 28 02-28-2006 05:30 PM
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 06:53 AM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
