700r4 tranny not shifting out of 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2006, 08:26 PM
Hi guys, I just started working on a 1987 Camaro and the 700r4 tranny will not shift out of 1st gear. It shifts smoothly into drive but no matter how high the engine revs the tranny doesn't shift. I've searched the forums and seen that the governer should probably be the first thing I look at, is there anything else I should look for?
Old 09-21-2006, 08:46 PM
scrot's Avatar
Why don't you think that is the problem? Just curious.
Old 09-21-2006, 08:48 PM
Because I would assume that if it was the governor the engine would be limited as to how high it can rev. ... of course we all know what happens when you assume.
Old 09-21-2006, 09:45 PM
Jmark's Avatar
The governor controlls the shift points in the trans, not the engine speed. If the governor is stuck or if the gear is stripped, it won't shift at all. Pull the big round cover off and pull the gov out and take a look, or maybe take it to a trans shop and ask them to ck it.
1st tech Post (probably discussed to death) T350 and 700R4 conundrum Kallie49 Transmission - Rearend 5 01-06-2007 11:23 AM
700R4 tranny shifting to fast at low RPM Danscam Transmission - Rearend 2 05-27-2006 08:31 AM
700R4 tranny shifting questions cares Transmission - Rearend 3 05-22-2006 09:42 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
700r4 not shifting out of 1st gear AKGMC Transmission - Rearend 2 06-08-2003 04:27 PM
