Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $5,528.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 06-24-2005, 02:05 PM
william27103's Avatar
william27103 william27103 is offline
700r4 tranny problems
after intalling the torque convertor on my brand new bowtie overdrives 700r4, me and my dad went to bolt it to the engine, and they wouldn't come together. So I took the convertor back off of the trans, and apparently, we didn't seat the convertor on the pump prong thingies right, and they are now broken off. How hard is it to take the trans apart and put in a new pump, and is there any way we may have damaged anything else.
Thanks guys, I've got to slow down and start being more careful...
Old 06-24-2005, 02:36 PM
347mustang's Avatar
347mustang 347mustang is offline
what broke
Old 06-24-2005, 05:12 PM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Streetbeasts lawsuit donor
Centerline's barnstar
Wiki editor
Last wiki edit: Streetbeasts fraud controversy
Wiki Edits: 38
If you're referring to the tabs for the pump gears you'll have to get a gasket and new gears. I'm not familiar with the 700R4 but most pumps are similar. Make sure you take the gear (with the broken tabs) to the parts house since they may come in different thicknesses and you want to get the correct one.
If the 700R4 is like the TH-400 and TH-350 then it's a fairly simple procedure.
On of the trans specialists may be able to elaborate on this a bit.
Old 06-24-2005, 07:09 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
It's a fairly easy fix to replace a front pump. Next time make sure the converter is fully seated.
Vince
Old 06-24-2005, 07:54 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Rob Keller's barnstar
Wiki editor
Last wiki edit: How to clean glass
Wiki Edits: 38
i did the same thing on my first install 25 something years ago!
the key is 3 clicks or bumps.
put the convert in place and slowly spin it while pushing(slightly) back (toward the tail shaft) it should fall into place after 3 clicks .
you know you have it right when you are unable to slip your fingers in between the bell housing and the converter at the top.
take your time learn it good and the speed will come to you naturally
good luck
sr66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 06-24-2005, 07:56 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: T-700r4 though 4L70E tips and tricks
Wiki Edits: 874
you need to determine what you wish to replace, the whole pump or the pump rotor only. 700 pumps have a rotor, slide & vanes not gears.
If you repalce the pump rotor only you need to verify thickness and clearance of the rotor to the pump.
iF you go with a complete pump , often they come partially assembled NOT ready to run. The pump havles need to be aligned & bolted together. Then you need to swap the valves from one assembly to the fresh unit
At the Bonneville Salt Flats... 130mph is known as First gear ..............
People have issues .. cars have problems
Old 06-24-2005, 09:15 PM
thanks guys, i'm just gonna replace the rotor, because the pump is brand new in a brand new trans, actually, my transmission shop is going to do it, because i don't have the time, i talked to him this afternoon
it was my first install, and i guess you learn from your mistakes, i definitely won't do it again
thanks
Old 06-25-2005, 05:37 PM
BigDawgsEatFirst's Avatar
BigDawgsEatFirst BigDawgsEatFirst is offline
400SBC4Life
I am not trying to be an a**
but with your transmission or converter
You Did not have directions with them
on this very important step.......
how much is it going to cost u
Old 07-01-2005, 04:30 PM
problem solved, it was just the pump rotor, no other damage, $20 = fixed
putting it in the car this weekend
Old 07-19-2005, 02:09 PM
benchracer1 benchracer1 is offline
Another 700 r4 problem. Shift points occasionally change to a higher rpm. Any ideas. How hard is a rebuild on that unit? I am a fairly competent mechanic and was succesful in rebuilding my honda accord trans.
Old 08-01-2005, 07:26 PM
mi73cam mi73cam is offline
700r4 trans problem
any ideas i have 95 700r4 when you drive it hard it developes a vibration that can get bad. the eng. was checked its fine, but the vib slowly goes away if you drive it easy. its in the tras shop now and there stumped. drive line was checked its ok, and 33112 mi. on truck all stock. help
Old 08-14-2005, 09:21 AM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
vibration
My son had a big Bronco AOD that did a similar thing. Turned out the lockup in the converter would slip and shutter a little. Tried Lucas and it helped for a while, finally had to replace the converter. Found out that this was THE EXPENSIVE F-350 4 wd trans behind a 351W.
Old 08-14-2005, 09:56 AM
xntrik's Avatar
trans mistake
thanks
I was married twice.
Old 08-14-2005, 10:28 AM
400SBC4Life
Just say you will do everything possible not to make the same mistake.
I had my 700R4 rebuild and the shop gave me such a good price on R and R (remove and replace Labor)
I drove it there and picked it up 3 1/2 Days later. 190.00 Bucks.
That price beat me laying outside in the parking lot and finding a knowledgeable helper.
Old 08-14-2005, 10:37 AM
400SBC4Life
Originally Posted by benchracer1
Another 700 r4 problem. Shift points occasionally change to a higher rpm. Any ideas. How hard is a rebuild on that unit? I am a fairly competent mechanic and was successful in rebuilding my honda accord trans.
It can be done
However you must measure and check certain items with that trans.
I did not do mine because I needed my truck as soon as possible.
My first 700R rebuild will be for my recreation vehicle and not my job transportation
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "700r4 tranny problems"
87 camaro 700r4 problems Dans83Olds Transmission - Rearend 3 03-13-2006 04:16 PM
700R4 tranny cooler....I need one. KeithB123 Transmission - Rearend 11 08-14-2005 09:48 AM
TH-350 - 700R4 tranny swap 73monte Transmission - Rearend 3 03-25-2004 12:26 AM
83 Z28 700r4 Tranny Problems Help! ZBAILEY Transmission - Rearend 2 11-09-2003 07:26 AM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 12:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
