Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 tranny question
Old 10-31-2006, 09:00 AM
briscoe briscoe is offline
700r4 tranny problem
You can see by the post from airworld2 you need power to [A] wire and ground to [D] wire.your not using the computer so you can't just plug in 4 prong connector,you must supply power and ground,again airworld2 post.I never liked the idea of a switch you can flip to bring lockup on.When the 1-2 shift valve strokes it supplies fluid to allow lockup,thats how some of these units could actually go into lockup in 2nd gear,and every gear after that for that matter.Airworld2 outlines an easy method for lockup,In addition if you want you could run in series,with your 12 v,a low vacuum switch,so if you romp on it the converter will unlock,low vacuum,open circut,no power to [A] WIRE.power returns when vacuum is restored,Crosley outlines yet another method,which may be, by your own admission,not within your capabilities.Hope this helps.
