Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 tranny to replace turbo 375
Old 01-29-2012, 01:18 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by 32 roadster
Could anyonr please hell me by telling me what I would need to do to replace turbo 375 leaking piece of junk with 700r4. I run four link in bach with 9 inch so I have room to move if the tranny is longer or shorter. lokar shift is 350 could i reuse it on 700r4. electric speed o meter . would I need to move tranny mount. any help would be great thanks
What length is the Tailhousing on the TH375, 9"? If so the 700R4 is the same length.
Shifter may work but, you wouldn't be able to manually shift to 1st gear.
Trans dimensions:
http://www.maliburacing.com/auto_tranny_id.htm
http://www.tciauto.com/tc/trans-dim
