-   -   700r4 tranny to replace turbo 375 (http://www.hotrodders.com/forum/700r4-tranny-replace-turbo-375-a-213448.html)
32 roadster 01-28-2012 09:13 AM
Could anyonr please hell me by telling me what I would need to do to replace turbo 375 leaking piece of junk with 700r4. I run four link in bach with 9 inch so I have room to move if the tranny is longer or shorter. lokar shift is 350 could i reuse it on 700r4. electric speed o meter . would I need to move tranny mount. any help would be great thanks
SSedan64 01-29-2012 01:18 AM
What length is the Tailhousing on the TH375, 9"? If so the 700R4 is the same length.
Shifter may work but, you wouldn't be able to manually shift to 1st gear.
Trans dimensions:
http://www.maliburacing.com/auto_tranny_id.htm
http://www.tciauto.com/tc/trans-dim
majic1on1 07-17-2012 12:44 AM
a place for information
i my self dont know much but i found a place that will have alll the answers for your questions,,,A and Reds transmissions in Wichita kansas phone number is 800 835 1007....i jus replaced a turbo 350 with a 700r4 they even figured out exactly what gears i needed in the700r4 ... told me about the flywheel and the mount ....was a very helpful companythere email is areds@worldnet.att.net... what got me is the prices if your a shop as i am ....igot all the gears housing and information for $19.80 that was a big help .....good luck... don ...aka majic1on1
