700r4 tranny to replace turbo 375 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2012, 09:13 AM
Could anyonr please hell me by telling me what I would need to do to replace turbo 375 leaking piece of junk with 700r4. I run four link in bach with 9 inch so I have room to move if the tranny is longer or shorter. lokar shift is 350 could i reuse it on 700r4. electric speed o meter . would I need to move tranny mount. any help would be great thanks
Old 01-29-2012, 01:18 AM
SSedan64's Avatar
What length is the Tailhousing on the TH375, 9"? If so the 700R4 is the same length.
Shifter may work but, you wouldn't be able to manually shift to 1st gear.
Trans dimensions:
http://www.maliburacing.com/auto_tranny_id.htm
http://www.tciauto.com/tc/trans-dim
Old 07-17-2012, 12:44 AM
a place for information
i my self dont know much but i found a place that will have alll the answers for your questions,,,A and Reds transmissions in Wichita kansas phone number is 800 835 1007....i jus replaced a turbo 350 with a 700r4 they even figured out exactly what gears i needed in the700r4 ... told me about the flywheel and the mount ....was a very helpful companythere email is areds@worldnet.att.net... what got me is the prices if your a shop as i am ....igot all the gears housing and information for $19.80 that was a big help .....good luck... don ...aka majic1on1
700r4, th375
Can you Replace a 200r4 transmission with a Turbo 350 TH3175 Transmission - Rearend 2 07-23-2011 06:45 PM
replace tranny or go with a gear vendors overdrive? mike69 Transmission - Rearend 2 09-10-2010 10:04 PM
Tranny Replace Dodge Dakota 4x4 V8 go raiders Transmission - Rearend 1 03-19-2008 12:04 AM
Replace sprag turbo 400 Cruzerbobby Transmission - Rearend 8 11-20-2004 10:34 AM
replace powerglide with 700r4 NO SHIFT Transmission - Rearend 0 03-10-2003 08:00 PM
