700R4 tranny shifting to fast at low RPM - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2006, 09:53 PM
Installed a 700 r4 tranny and it seems like its shifting to fast when in drive.when i manually shift ,it works great. Can somebody help me out with this problem. maybe something needs ajusted,replaced etc.
Old 05-18-2006, 10:00 PM
Crosley's Avatar
Wiki Edits: 1659
is the tranny TV cable setup correctly and has full pull of the TV cable at wide open throttle?
Old 05-27-2006, 08:31 AM
Need to get a shift govern kit. The govern is in under the 3" round dome looking thing on the side of the transmission. The cover just pry's off and you can pull out the governor. The govern has weights on it (like a distributor advance) and the heavier the weights the sooner it shifts. There are some welded weights on the spinner that you can cut off. The lighter the weights, the later it shifts. There is a govern kit available that has different weights and springs.
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 06:53 AM
C-6 tranny not shifting in 3rd 66 T-Bird Transmission - Rearend 1 09-13-2005 08:22 PM
TH-350 - 700R4 tranny swap 73monte Transmission - Rearend 3 03-25-2004 01:26 AM
700R4 not shifting Stuckinthemud Transmission - Rearend 5 03-04-2004 09:01 AM
Engine Knock at low RPM Paco Engine 8 08-19-2002 06:12 PM
