700r4 tranny swap different plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2011, 06:26 PM
hello my son has a 1993 chevy with a 350 motor tranny is 700r4. the tranny went bad and we purchased another 700r4 out of a 92 chevy. the plug in is different and im a mom with not alot of money. will this difference in yr cause a problem? can the plugs just hang and be plugged with protection or is there possible an adaptor to interchange the 2 different plug ins? thanks a bunch. mom trying to get her kids truck fixed
Old 11-26-2011, 07:03 PM
sorry also his truck is a 1993 four wheel drive. Im aware that it cannot pull heavy stuff but just need to know what i need to make the change. we have someone switching the tranny but we hate to start installing and find out later it wont work at all or needs something else to run correctly.. Thanks
Old 11-26-2011, 07:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A 1993 Chevy truck has the 4L60e trans in it. There is a connector for electrical on the passenger side of the trans, about 1.25 inches in diameter. The 4L60e trans is electronic controlled shifting and pressures.
The 1992 trans would have a square connector on the driver's side of the trans case with 4 holes in it.
These two transmissions are not interchangeable
Old 11-26-2011, 07:45 PM
pricesgarages's Avatar
700 plug in
1993 was the first yr of the 4l60 E wich is fully electronic no governer or tv cable controled buy the pcm the 92 is a 4l60 (700r4) wich only has a electrical plug in for the lock up torque converter u can use the 92 but u need the cable your tuck will have the bracket on the throttle body to hook it to the check engine light will stay on because the big plug is unhooked 700r4s dont like contaminated fluid so u should run a new cooller u can auctually fit 2 on a full size truck
Old 11-26-2011, 08:13 PM
So is it? or is it not interchangable? new rebuilt tranny came out of a 92 four wheel drive. I appriciate your help a bunch been sitting here waiting on an answer. I just need to make sure if they can be converted or not and what needs to be done to make the change maybe? Some tell me they used several differnt kinds of trannys in the 93s trucks. I kinda have 2 different answers here and not clear on what to go with. no pun intended just looking for honest help Thanks
Old 11-26-2011, 08:28 PM
it will bolt up excatlly the same like i said u need the cable hooked up corectly your 93 doesnt use a kickdown cable so u need one for the 92 but you will have a check engine light on doing this you can not put a 93 in a 92 because u need a ecm to shift it
Old 11-26-2011, 08:41 PM
ok Thank you so much. your help is much appriciated. I just wanted to get some extra info before we do the change. seems everyone is sure it will work and we have the cable so we are good. Glad I got on this site
Old 11-26-2011, 08:47 PM
other thing jegs and summit sells a lock up kit thats the 4 wire plug on the driver side i personally dont use the lock up on my rebuilds and never had a problem i also live in wva witch doesnt have many staight flat roads so the louck up aways engages and disngauges during normal driving the fact your living in the mid west were its flat for miles u may want to use the lock up and once again use a new cooler with the 700r4
Old 11-26-2011, 08:56 PM
Thank you I showed your response to the guys here and its very useful. we will also check into the kit. he doesnt use it for long distances. more for back and forth to school in winter its restored and he drives 2 wheel drive lil truck in good weather your a trooper thanks a bunch grately appriciated!!!
Old 11-26-2011, 10:28 PM
ok thanks i know all about working on a budget
Old 11-27-2011, 08:33 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
diamond, I provided you an honest answer.
As mentioned by joshp with the plug in connector for the 4L60e trans unplugged , the PCM will set trouble codes and turn on the "check engine" lite in the dash.
The onboard computer in the truck looks for feed back from the 4L60e trans. When you install the earlier non electronic trans the system does not operate properly. The truck will run and drive.
Good luck
700r4 tranny swap gcollins814 Transmission - Rearend 3 11-24-2011 10:35 AM
TH-350 - 700R4 tranny swap Hookers Garage Transmission - Rearend 6 05-20-2009 11:09 PM
700r4 tranny swap Addicted2Gas Transmission - Rearend 1 08-11-2008 09:14 AM
TH-350 - 700R4 tranny swap 73monte Transmission - Rearend 3 03-25-2004 02:26 AM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 02:52 PM
