700r4 trans output shaft question
i have a 90 k5 blazer 700r4 the tranny just went out, im looking at a 91 camaro that has a 700r4, would that tranny fit?
thanks |
No...The Blazer has a shorter output shaft and rear housing to adapt the transfer case to it.
Ontario Rodders |
wat if the adapter was changed
there is no adapter to put a 2 wheel 700r4 - 4L60 trans in place where a 4x4 700r4 - 4L60 trans was.. the 4x4 out put shaft is shorter. if you put a longer trans setup in there , everything is moved back. T-case is moved , t-case shifter is moved , cross members moved , drive shaft lengths change
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Change shafts, or find another transmission. |
You will need some new gaskets and seals. The inspection plate cover may not fit or may need holes drilled to mount it, not sure. |
Just looked at the original post again.......I was assuming that this Blazer was a 4x4....If it is, the tailshaft is too short and is a different style to work. To change the tailshaft and housing, I believe the whole tranny must come apart.....If its a 2 wheel drive Blazer, it may fit, I am not sure of the tailshaft length on those.
Is it a 4x4?
Ontario Rodders |
Usually a K series blazer is a 4x4... maybe it is a 2 wheel drive
I was assuming 4wd as well.
yes it 4x4
how durable is the 700r4? offroad wise?
| 700r4 accumulator question | oldchevy1956 | Transmission - Rearend | 2 | 05-04-2008 04:43 PM |
| Different size output shaft on c4? | nitrous_69stang | Transmission - Rearend | 3 | 04-17-2006 10:51 AM |
| Crosley?? T-400 Output Shaft 'O' Ring | 68NovaSS | Transmission - Rearend | 2 | 12-13-2005 06:35 PM |
| 4l60e trans question | silm man | Transmission - Rearend | 12 | 10-23-2005 03:10 PM |
| transmission 700r4 output shaft slop | catscan4free | Transmission - Rearend | 3 | 01-25-2004 08:11 AM |
