700r4 trans problems , TV cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2009, 04:04 PM
Can you check for electrical current with car sitting still and key on at the trans. plug in? also, does the detente cable have to be set all the way back, before setting the throttle forward to ratchet it forward, or do you have to take out the slack first? I can get first gear shift to second at fifteen to twenty mph, but no second shift to third gear. Don't know if it is locking up or not. Any help would be appreciated.
Old 07-04-2009, 06:51 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Will you please tell us exactly what your working on.
Rich
Old 07-04-2009, 08:11 PM
700r4 trans problems, TV cable?
If that trans is shifting late like it sounds like, start setting the cable where it's at. Mark the position the slide adjuster is at now for reference and then release the lock mechanism and slide the adjuster forward slightly which will reduce tv pressure so it can shift earlier. Tinker with the position until you can start getting 3rd in at 23-28 mph under very light throttle. 4th should fall in place slightly higher.
Old 07-05-2009, 10:12 AM
Originally Posted by richard stewart 3rd
Hi
Rich
I am working on a 1985 blazer. 350 stroked with 1989 700R4 trans.
Old 07-05-2009, 06:54 PM
Hi,
At The Assembly Line Diagnostic Link, connect one end of a test light to terminal A the other end to terminal F turn on the
ignition the light should light, if it lights you have voltage to terminal A at the transmission.
Rich
http://www.tvmadeez.com/
http://www.tvmadeez.com/article/index.php
Bolt holding TV cable in the Trans. grumpy1 Transmission - Rearend 2 12-28-2007 10:04 PM
700r4 TV cable too short? Thoughts? ericbr Transmission - Rearend 10 08-01-2007 08:07 AM
3 duce 700r4 tv cable mount anglia48 Transmission - Rearend 2 07-15-2003 12:16 PM
