700r4 trans shift problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2006, 08:44 AM
I have a 68 GMC with a goodwrench crate motor and a 700R4 trans installed by a previous owner. I've driven this truck for 7 years with no problems. I drove this truck to work one day and when I drove home in the truck it wouldn't shift out of first. I checked the fluid and it had plenty. When I put it in gear it sounds solid and pulls fine. It has reverse and 1st gear. It just will not shift up. I have not seen any electronics on this tranny. It does have a cable. I don't know what year of tranny it is. I've never worked on an automatic trans. before. Any help would be great.
Old 10-26-2006, 03:52 PM
Stuck tv valve or gear damaged on governor are the most likely cause.If you have access to a 0-300psi pressure gauge tap into mainline pressure port,located right above manual linkage pressure in park should be about 65-70psi,if up around 90-95psi the tv valve is sticking,if pressure is good suspect bad gear on governor,drivers side 2/3rd the way back of trans.
Old 10-26-2006, 03:56 PM
just went thru this same prob. check out my posts
400 w/brake shift problem hotrod Transmission - Rearend 4 06-23-2005 12:14 AM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
700R4 Shifting Problem mann1961 Transmission - Rearend 2 06-12-2004 01:39 PM
