700R4 trans. shifts to hard - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2009, 08:00 PM
I just bought a 87' chevy silv. 4x4. It has A recent rebuilt jasper engine with a holley 502-6 TBI and shifts really hard from fisrt to second at about 4500rpm. before it shifts it starts to bust up. do i have a shift kit or is it as simple as a vacuum leak?
Old 03-24-2009, 08:31 PM
SSedan64's Avatar
700R4 Hard shift
Trans TV cable may need adjusting, too tight. The TH700R4 does not have a vacuum modulator. As for busting up may be ignition or ECM not clibrated for the larger TBI.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 03-24-2009, 08:56 PM
fast68's Avatar
likes chevy trucks & boobies
700r4 also will wind up high rpm and shift extremly hard if the cable is not connected at all
not connected, or not set correctly are both horrible for the trans
dont drive it again until this is corrected
how many miles are on the trans ?
hows the fluid look and smell ?
Old 03-25-2009, 11:11 PM
I looked at the truck tonite and noticed the trans. line has a little kink (not collapsed) and a partial burned cable from trans. to the transfer case to close to the exhaust
700R4 Trans yoke U-Joint 1310 or 1330? Cole Transmission - Rearend 6 11-10-2008 12:54 PM
700r4 rebuilt but noisey shifts dch921 Transmission - Rearend 2 08-25-2008 09:59 PM
700R4 shifts erly 694X4 Transmission - Rearend 2 11-18-2007 11:45 AM
1989 4l60( 700r4) shifts from 2nd to neutral Riby Transmission - Rearend 10 04-07-2006 01:51 AM
T-400 Shifts Hard 74_Chevy Transmission - Rearend 19 12-29-2005 06:33 PM
