Originally Posted by blwn31
Brad, I didn't do it that way when I rebuilt my 700R4. But different strokes... Check every gear in manual position with minimum TV pressure and max TV pressure. For minimum TV pressure just read the gauge with the trans in the selected gear. To get max TV pressure pull the TV cable at the carb or throttle body all the way out and read the pressure. I have an ASTG manual all the mins and max pressures if you need me fwd them to you.
Keith
Thanks, I sure could use that info and would really appreciate it.
Brad...
Just put a new converter in and pretty close to firing it up and seeing what it does.
