700R4 trans woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2003, 03:08 PM
700R4 trans woes
Ok, here's my deal, I running a 89 K1500 4x4 with a mildly cammed 5.7L. Initially the trans split the rear planetary ring, trashing up the case with stuff. Had it rebuilt, told the guy it was hitting 2nd a little harder then normal b4 it grenaded. He put some kind of restrictor in the pump to slow up the 1-2 shift. Drove me nuts, cause it would pause then shift. Anyway it lasted for 40k miles, then a thrust washer in the converter went, and I limped home. Took it to him again and he rebuilt the entire trans for the 2nd time...all new seals, disks, drum, converter, etc. Got it back and it would not go into lockup. He thought the thermal switch for the solenoid was bad and replaced it to no avail...blamed the issue on my chip tuning, which I hadn't touched any trans lockup points with anyway. Later, about 500miles later, the converter starts locking correctly. After about 2-3k miles the convertor will only lock if the drivetrain is under load. IE, coasting or flat lands it unlocks. Now about 10k miles later, if run for longer then 30min it won't lock at all...but cold it will until normal engine temp, it starts acting funny again. I'm wondering if the restricter plug he put in is killing the converters and does the last symptoms sound like just a bad converter?
Any insight?
Doug
Old 10-22-2003, 07:35 PM
airworld2's Avatar
700 trouble
I think that guy is pulling your leg ..... you can replace the two boost valves in the pump for better line pressure and firmer shifting, sound like you need a better transmission re-builder most people wouldn't go back for 2nds on a bad repair job you been back for more than that are you paying for all the work after the first time? on course opinions vary here
sounds like it did the famous slide, bump 2nd gear shift which can be easy to fix
far as lock up sounds like incorrect ecm ground trouble when tranny fluid hits 275 degrees thermally switch will close and 4th gear pressure switch will provide ground to lock up solenoid if that switch is working
Old 10-22-2003, 08:04 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
Find another tranny builder, this one does not know what he is doing.
Old 10-23-2003, 08:58 AM
Hey thanks for the replies, yeah I ain't goin' back to him for sure. He did say that the restrictor was press fit into a line...not sure if it was the pump or not. Apparently the restricter has a narrow orafix to slow fluid from making the 1-2 shift. I'm wondering where this freakin' thing is and if I can't find it, it'll force me to purchase a total rebuilt replacement. I'll definitely check the grounding issue, though i think the trans is lossing pressure somewhere. When accelerating on a hwy ramp, it kinda' pulsates, like it's slips and catches, in quick session. Motor sounds like a donkey, you know eee, haw while this is goin' on.
Doug
