700r4 transmission drive shaft not right?
switched out th350 for 700r4. shortened drive shaft, if i didnt shorten enough what can happen? drive shaft didnt have any play hard to take out wouldnt slide forward enough had to pry to get out. tranny worked great for 3000 miles, now its shot doesn't go any where. oil smells good ,good color,no pieces in pan.thanks for any suggestions
There are a few guys on this site that are up on those 700s. You need to add some more for them...
-Did you make sure that the lock-up was really working during those 3000 miles? -Was the TV cable adjusted correctly? |
700r4
No forward and no reverse? Was the trans working fine, then it just stopped moving?
With a no forward or reverse condition, and you said the fluid was not burnt and there was nothing in the pan, it may point to a failed torque converter. This would be better than an entire trans failure, of course you will need to correct the driveshaft situation. |
IF the drive shaft is too long... It put pressure against the out put shaft and pushes the internal gear train of the transmission forward.
This can damage many items inside the trans.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
trans damage
Check torqe convert easy. If it doesnt have a lockup cluch it iot. Just put a pair of plires that open up and turn sprag should turn 1 way only . If you have a lockup cluch in it hard to tell. It wears like the other cluches. You can check backside of converter and see if the paint has changed color from heat<means it is slipping> or just look and see if any cluth matieral falls out. When I rebuild a trans with alot of miles on it I will change the converter. The old ones with no lock up last forever as long as sprag is good and also make sure the hub that goes in tranny is not pitted or messed up. You can clean it up some with some wet dry300-400 sand paper. |
mr j....
the trans quit for a reason. Did you open the filter up to see if the debris was sucked up into it and clogged the filter? IF you are a DIY , you may not see some damage ... just a thought. Have the converter checked out by a competent shop... the internal drive hub can break off the turbine inside the converter.. If that happens there is no transfer of power.... no movement of the vehicle
700r4 problem
thanks for your help Im going to a shop and check torque converter.
| 700r4 transmission running hot | all gm | Transmission - Rearend | 4 | 12-08-2006 04:46 PM |
| Internal Reaction (Ring) Gear shattered in 700R4... | indy_85stariones | Transmission - Rearend | 8 | 11-30-2006 05:31 PM |
| 700r4 transmission problem | msmaddog | Transmission - Rearend | 2 | 10-14-2005 09:54 PM |
| Transmission Information. | M&M CUSTOM | Transmission - Rearend | 1 | 08-24-2004 03:15 PM |
| Best gear ratio when installing 700r4 transmission | agordon | Transmission - Rearend | 6 | 02-18-2003 08:05 AM |
