700R4 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2008, 01:43 PM
700r4 tanny's
Hi Hot Rodders
I just purchased a 1984 Corvette, it is decent shape but needs some tlc and on my first joy ride in it I took off and got up to about 55 MPH and the transmission quit pulling, if I put it in any forward gear it does nothing, but if I put it in reverse it will move but acts as though the brakes are locked up. Any ideas what be transpiring?
Old 06-14-2008, 01:45 PM
700R4 Transmission
Hi Hot Rodders
Old 06-14-2008, 02:08 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders....This is the Introduction forum so....it would be best if you asked your tranny questions over in the Transmission/Rearend forum. You will get more answers that way.
Old 06-14-2008, 06:53 PM
poncho62's Avatar
Wiki Edits: 5
moving it....Sounds like your tranny is pooched.....
Ontario Rodders
Old 06-15-2008, 02:01 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Originally Posted by lcanezaro
Hi Hot Rodders
Fluid brown and burnt smelling?
Forward clutch fried. (no fwd. movement)
Binding in reverse is probably from the steels in the fwd. clutch being severely warped and not releasing fully.
If the fluid is bad- time for an overhaul.
Old 06-16-2008, 09:48 AM
700r4
Thanks for the input on my problem, that is what I was thinking but I guess I wanted to hear it from someone else before I pulled it and sent it off to get rebuilt.
Thanks for you input again.
First Transmission Rebuild - 1990 700R4 Downcast Reject Transmission - Rearend 9 05-07-2008 09:49 PM
v6 700r4 transmission leldai73 Transmission - Rearend 2 05-06-2008 11:07 AM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
700r4 transmission problem msmaddog Transmission - Rearend 2 10-14-2005 09:54 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
