700R4 Transmission no 2nd gear
Just rebuilt a 700R4 transmission and there's no second gear :confused: . What could be the cause. ): ):
Hi,
Welcome to HotRodders.com Glad to have you with us. :welcome: Just so you know, the next time your asking for a diagnosis, it would be beneficial to give as much information as possible in order for whomever to give an accurate answer. From what info you have given, remove the governor clean it & the hole it came out of thoroughly. Rich |
no 2nd gear
thanks for the advice i will check it out
fixed
it was the outer 0 ring on the second apply servo piston it has damaged when it was put in so it was leaking in to 3rd gear so it was shifting from 1st to 3rd .yeahhh im happy now
| All times are GMT -6. The time now is 10:16 PM. |
