700R4 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2009, 08:11 PM
700R4 Transmission no 2nd gear
Just rebuilt a 700R4 transmission and there's no second gear . What could be the cause. ): ):
Old 03-10-2009, 05:40 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Welcome to HotRodders.com Glad to have you with us.
Just so you know, the next time your asking for a diagnosis, it
would be beneficial to give as much information as possible in order for whomever to give an accurate answer.
From what info you have given, remove the governor clean it & the hole it came out of thoroughly.
Rich
Old 03-10-2009, 10:01 PM
no 2nd gear
thanks for the advice i will check it out
Old 03-11-2009, 07:15 PM
fixed
it was the outer 0 ring on the second apply servo piston it has damaged when it was put in so it was leaking in to 3rd gear so it was shifting from 1st to 3rd .yeahhh im happy now
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 03:50 PM
ID a 700r4 trans? lishman Transmission - Rearend 3 03-22-2008 10:30 AM
Pressure check 700r4 transmission? grumpy1 Transmission - Rearend 3 02-21-2008 06:25 PM
gm 60deg v6 4x4 700r4 transmission grumpy1 Transmission - Rearend 0 02-12-2008 09:11 PM
700R4 transmission install Decho Transmission - Rearend 3 08-13-2004 11:54 AM
