700r4 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2009, 12:33 PM
700r4 transmission
i have currently a 700r4 transmission which i've toasted and i plan on replacing it with a turbo hydromatic that i have in the basement but i am having difficulties identifing the actual one i have . just says 75cp on a tag and a serial number 113 which is all i can read. plate says cinn motor corp. could anyone help with this it is also a short tail 28 inches long.
Old 07-06-2009, 01:47 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Welcome to HotRodders.com Glad to have you with us.
Rich
http://www.google.com/imgres?imgurl=...num=1&ct=image
Old 07-07-2009, 11:52 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
As you can see from the link posted above, you'll need to move the crossmember and get a longer drive shaft. You may have less headache in just having the TH700R4 rebuilt.
Question on 700r4 transmission tail shaft and front shaft eric32 Transmission - Rearend 11 05-10-2009 12:03 PM
ID a 700r4 trans? lishman Transmission - Rearend 3 03-22-2008 10:30 AM
Pressure check 700r4 transmission? grumpy1 Transmission - Rearend 3 02-21-2008 06:25 PM
gm 60deg v6 4x4 700r4 transmission grumpy1 Transmission - Rearend 0 02-12-2008 09:11 PM
700R4 transmission install Decho Transmission - Rearend 3 08-13-2004 11:54 AM
