700R4 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2002, 02:21 PM
Post 700R4 transmission
Is there a good book on the hows & don't and what
to do on rebuilding and hopping up a 700R4 tranmission <img src="confused.gif" border="0">
Old 10-21-2002, 08:18 PM
BOBCRMAN@aol.com's Avatar
Post
if you are a novice don't go there the trans is very touchy, has had many little changes over its production run and five revisions, if you want real trouble open up a 700r with little or no experiance with them. some of them will even make a pro cry. good only if every thing is right on, and even the factory built few of those.
Old 10-22-2002, 06:38 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Contact http://www.bowtieoverdrives.com/. They have everything you need to become an overdrive transmission expert.
Old 10-22-2002, 07:20 AM
slider in wa's Avatar
Slider in Wa.
Post
When prepared right this is simply the best tranny for me. However i have burned up a couple. It is important to use a later than 86 with all the mods done to it. There is no way i would tackle rebuilding one of these. You need a ton of special tools. It is cool doing a smokie burn out!!! And then being able to drive 65mph at 1600 rpms though. Do not tow with this tranny in overdrive. Good luck, and keep us informed.
Slider in Wa.
Old 10-22-2002, 10:42 AM
Post
Thanks guys I thinks I will go whit gear vender
for my over drive
