700R4 transmission cooler line routing. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 05:29 PM
Like an idiot I removed both transmission lines, made new ones and now I cannot remember where they attach to the radiator at!
On the 700R4, I know the bottom transmission line on the right side of the trans is the "out" line but does it go to the top of the radiator or the bottom of the radiator? My radiator has a top and bottom connection for the trans lines Vehicle does not have a trans cooler. (4L60E Chevy C1500 5.0 )
Thank You
Old 01-30-2011, 06:36 PM
SSedan64's Avatar
Trans Bottom line "out" goes to Bottom of Radiator. Trans Top line "in" goes to Top of Radiator.
No pressure in cooler lines on my 700r4 transmission in my 89 Suburban AMadrid Transmission - Rearend 2 02-21-2010 03:00 AM
transmission cooler line fittings yragat Transmission - Rearend 19 02-11-2008 12:23 PM
Transmission (broken) cooler line fitting extraction 78 monte Transmission - Rearend 1 10-21-2007 02:36 AM
Transmission cooling line pressure 700r4 grumpy1 Transmission - Rearend 4 08-22-2007 08:34 PM
Vacuum line routing Bad Rat Engine 1 08-26-2005 09:29 AM
