-   -   700R4? transmission ID (http://www.hotrodders.com/forum/700r4-transmission-id-213482.html)
David R. Eaton Sr. 01-28-2012 05:39 PM
Hi,
I purchased what was supposed to be a 700R4 out of a 2WD Chevy Suburban. I don't know what year the vehicle was, but I do know the engine was a 454. There is no T.V. Cable, but there is a vacuum modulator on the fwd right-hand side of the case, and about 10 inches behind the shifter cable attachment point there is a wire connection, for 1 wire with the small round rubber boot.
On the (L) side of the bellhousing there is a raised 46, and on the (R) hand side of the bellhousing there is a raised HD. There is a shiny tag on the (R) side of the case w/ J69 near the top, and below that is 87 1YA 8415. With the information I've provided can you give me any idea what I purchased?
Thanks for your time!
mafiacustomz 01-28-2012 06:17 PM
if i had to guess by whats on it 4l60e from a 94 newer car
Crosley 01-28-2012 07:39 PM
Originally Posted by David R. Eaton Sr.
Hi,
You describe a T-400 transmission.
There is no vacuum modulator on a 700r4 or a 4L60E trans.
There would be a TV cable on the 700r4 / 4L60 trans.
:pimp:
SSedan64 01-29-2012 01:27 AM
X2 ^^,
Trans ID by Pan shape >> http://www.maliburacing.com/auto_tranny_id.htm
