700r4 transmission mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2013, 10:52 PM
I went to put my 700r4 in, the cross member didnt work right because the motor mount I had was for a 4l60 and even though they was the same size for some reason it just would not fit right, I don't think I need a new cross member but the one I have came with my 1990 s10 4.3l I can put everything in but the bad part is getting that cross member to work I think because I still have the block of wood under the engine for when they took the tranny off in the first place but if anyone knows what could fix this problem or if I need a new crossmember please let me know. Also its a 2x4 auto tranny, the mounts I found have 2 holes and some have 3 so if anyone knows where I can buy a cheap one that will do the job please let me know
ID:	76478   Click image for larger version
Transmission mount Babyburr Transmission - Rearend 2 04-30-2011 09:02 PM
C6 Transmission Mount martin c Transmission - Rearend 0 06-24-2007 02:20 AM
transmission mount Lonestar Transmission - Rearend 24 12-04-2006 08:34 PM
Transmission mount srfzup Transmission - Rearend 3 06-03-2004 09:32 AM
Transmission mount arborlis Transmission - Rearend 2 04-14-2003 06:55 PM
