700r4 transmission yoke lenghts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 04:21 PM
I searched for different yoke lenghts for the 700r4 and did not come up with anything. I have one that is about 5 1/2" from the end to the center of the uj. I think I saw one at the junk yard that was about 7". What I need to know is how many lenghts were there that would fit a '90 700r4. I don't know what mine came out of, but a yoke from a 4cyl auto s10 fits.
Also would using a longer yoke be a good idea for gaining lenght in order to use a one piece shaft, or will the vibration be worse because the joint is farther from the tail shaft? help!
Old 09-11-2007, 08:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I can not answer the question on yoke lengths..
Many yokes from various GM trans fit the 700/4L60 trans... t-200 , t-350 , 2004r all fit the 700/4L60 trans.
I would suggest using a yoke that matches the U-joint you have on the differential if possible.
A drive line shop should be able to answer the question on how long a drive shaft is possible with out problems.
Transmission yoke th350 mrl Transmission - Rearend 2 06-21-2007 12:23 PM
700r4 transmission running hot all gm Transmission - Rearend 4 12-08-2006 05:46 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 06:31 PM
700r4 transmission problem msmaddog Transmission - Rearend 2 10-14-2005 10:54 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
