700R4 trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 01:44 PM
67 Firebird
700R4 trouble
Full story:
Trans (car) has shuddered in 4th gear since I got it. I thought it was due to the wrong power valve, but that didn't resolve the problem. Went to a car show a few weeks ago, at first it would not shift to 4th, just hung in 3rd, After it warmed up it would go from 4th to 2nd with the slightest touch of the throttle. I thought I might have a kickdown cable issue, but never looked into it. I took the car to get it aligned just now and it has no 3rd gear at all. It shifts 1st, 2nd, NEUTRAL (no go). No matter what I do I can't get it to engage third, it just spins. 1st and 2nd are still strong.
Any ideas what might be going on?
Old 03-16-2012, 02:02 PM
67 Firebird
Well, some reading tells me I've almost certainly lost the 3/4 clutches. Any way to make these things bulletproof under real power, or should I look for something else? Car has 4.11 gears so would like to keep an overdrive.
Old 03-16-2012, 08:01 PM
sqzbox's Avatar
My pipes are my music
Before I would pull the tranny , I'd check the condition of the shift gov.
Old 03-17-2012, 10:42 AM
SSedan64's Avatar
If the 1-2 shift is normal the Gov is probably Ok but, worth checking as said above.
Best option for reliable 3-4 Clutche is the Raybestos 'Blue Plate Specials'.
The Carbon type 2-4 Band is best.
Part No. RCPBP-21
Clutch PackŪ Module, Maxpak, Blue Plate SpecialŪ
With 3rd, 4th Clutches.
Old 03-19-2012, 08:00 AM
67 Firebird
I didn't think this transmission had a shift solenoid, all hydraulic I thought?
Old 03-19-2012, 06:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Nobody mentioned a shift solenoid. They both mention the governor which they label ''gov , GOV"
Old 03-23-2012, 03:13 PM
67 Firebird
Sorry guys, it was one of those days. Between being busy and bummed about the failure, I read the post wrong. I'm going to dive in hopefully in a couple of weeks (I travel a lot) and see if that's the issue.
700R4 trouble JCS 636 Transmission - Rearend 13 09-28-2009 08:43 AM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
700R4 trouble shooting help Not A T 25 Transmission - Rearend 7 09-05-2007 09:59 AM
700R4 trouble kuhn-77 Transmission - Rearend 1 07-26-2006 02:49 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
