700R4 trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 11:34 PM
kuhn-77's Avatar
Build it right the first time
700R4 trouble
I have a 1989 Chevy Silverado with a 350 TBI small block and a 700R4 Tranny it will shift very very hard into second gear, almost barking the tires, and it will quite frequently miss third gear and the rpm skyrockets but if you let off of it it will eventually go into third and you may continue on. If you put it into drive it will never miss third, only if its in overdrive it will miss third....but it will always shift into 4th or overdrive gear fine...... any idea's to this prob?
Old 07-26-2006, 02:49 PM
700r4 problems
beings the 4L60e didn't show til 94 we will start over check the throttlevalve cable adjustment first if ok the hard shift and the flair could be caused by the govenor sticking. but still could be the roller clutch/sprag any metal in this trans can cause shift problems,but checking line pressure as per manual will help determ. if you have hard parts failure or govenor problems
Last edited by Grit54; 07-26-2006 at 06:33 PM. Reason: sorry was thinking about my sons 94 Z71
V6 or V8 700R4 swap? cacsmret Transmission - Rearend 4 05-05-2006 09:28 PM
700R4 help/advice Mustangsaly Transmission - Rearend 7 12-12-2005 04:54 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 02:17 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
