Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 troubles
Thread: 700R4 troubles
Old 11-19-2012, 03:45 PM
ASE Doc ASE Doc is offline
I am a novice when it comes to transmissions. I have my own 700R4 torn down right now and have a question posted here concerning some performance mods I'm considering. Having said that, one thing I can think of that might cause your trouble would be a stuck 2-3 shift valve train. This is a valve set in the valve body and it may have debri stuck in it from the 3-4 clutch failure. There could also be a check ball out of place I suppose. The 2nd clutch and 3rd clutch check balls are the two close together, about the center of the separator plate. These are just slightly educated guesses.
