Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 troubles
Thread: 700R4 troubles
Old 11-22-2012, 09:06 AM
90K1500 90K1500 is offline
Good News! The sprag was the problem. Now I have another problem. First the transmission was shifting just fine, then it wouldnlt leave first. Then after a couple WOT runs it finally went into 2nd, then repeated the prcoess for 3rd and OD. I have a feeling that the TV cable and/or the small amount of engine assembly lube I used to retain the balls in the valve body while assembling have something to do with this. My last resort is going to be a bad valve body.
