Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 troubles
Thread: 700R4 troubles
Old 11-26-2012, 11:48 AM
ASE Doc ASE Doc is offline
Whatever was sticking must have broken loose. That's always good. One product I have had great luck with that helps keep things lubed up and prevents sticky valves is Lubeguard Red. Others may chime in on this but Ive used it in every GM transmission Ive ever had apart. I even used it to unstick the 1-2 valvetrain on a 700R4 that was having trouble shifting out of first. You may want to add a bottle to your fluid.
