700r4 troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2005, 01:40 PM
700r4 troubles
just instaled the transgo reprogramming kit.pretty sure i followed the destructions closely. pluged some holes, drilled some holes, changed some springs, ect. now, it bearly pulls in forward, and doesnt seem to pull at all in reverse it seemed to pull in reverse at first, then i cut it off and added sopme fluid, then nothing.anyone have any suggestions? something come loose?my head hurts from laying on my back alll day long and dont realy feell like taking it back a part
Old 10-22-2005, 06:59 PM
well, i fixed that
i didnt have the snap ring in the right groove, and it popped out.
butm this stupid tranny still wont hit 2nd gear, i believe i may put the turbo back in it,just dont like running 3500 rpms down the highway
Old 10-22-2005, 09:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by onesweetpink63
well, i fixed that
good for you .
Old 10-23-2005, 08:54 AM
thanx, but why wont this tranny shift hard?
Old 10-23-2005, 11:51 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I have no idea.
What did you do incorrectly?
Old 10-23-2005, 01:16 PM
i was hoping you would tell me
the kit had in the directions(for the servo) to remove the clip and a large spring and install some washers and a different spring. i had the vette servo in there before, do you think i shoud have stuck with the vette servo, or stayed with the directions? its kinda aggervating to do it in the car. i dont know if that would make a diff. in the way it shifts, it seems to rev high in between the shifts now, like it slips?
Old 10-23-2005, 04:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what servo have you installed?
all I see is the vette servo was removed.
if you installed a part and did not follow directions for that part, how can it function correctly?
THe servo on the side of the case is a multi function unit. IF setup incorrectly you will have poor 2-4 function, also possible to mess up 3rd gear too
Old 10-23-2005, 07:49 PM
when i had it rebuilt , i had a .500 boost valve,ad a vette servo installed.when i put this kit in,i followed thier instructions,and took the big yellow spring out,instaled some washers,and a small spring on the outer part,inbetween the cover part, and the part under it.maybe i should put the servo back the way it was and try it? i think i lost the clip though
Old 10-23-2005, 10:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You must have read the instructions wrong or something if you left the clip out. The instructions tell you to "temporarily" leave out the "E clip , washer and spring" during the band clearance adjustment phase with the washers that replace the large spring.
After the band adjustment is correct , the instructions tell you to reassemble the entire unit including the "E clip , washer & spring".
Is this what you did?
Old 10-24-2005, 06:37 PM
no. i did that.i left all the washers in and took out one thin washer.i installed the spring and washer and c clip.i discarded the snap ring,and the cushion spring like the directions indicated.
if your not sure, i can figure out how to post a pic of the directions.e it out before i change it out.cause i really like the gas milage
thanx crosley for the info,and some more if you have any!
Old 10-24-2005, 06:40 PM
do you think i should put it back the way it was and try it?(servo)
Old 10-25-2005, 12:56 PM
GoneNova/406's Avatar
i understand how you feel,i just had the valve body out of my 350 5 times only to find out that i was installing the kit properly after all.after reaching my limit and getting upset i had to step back for a minute and take a break.it usually comes to me when i do that.after listening to crosley and B&M i decided to check my vaccum lines to be sure and then found my pvc valve out of its hole in the valve cover.its never done that before.hang in there you'll get it and it will have been worth the effort.
Old 10-25-2005, 06:04 PM
i hope so, its gettting close to 1000$ bucks in this tranny already.. hate to just throw it away
what you think crosley? should i try the corvette servo again,see what it does?
Old 10-25-2005, 10:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the tranny does not function correctly now , so I would install the vette servo in the OE configuration and see what happpens.
I use dozens of the vette servos every month, the 1-2 shift is very firm the way I set them up
Old 10-25-2005, 11:59 PM
Jmark's Avatar
Are you saying that putting the PCV valve back into the valve cover fixed the shifting problem?
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 07:53 AM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 03:17 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
