700r4 troubleshooting/questions?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2011, 03:36 PM
My 90 silverado was shifting fine until one day coming home from work it wouldn't shift gears unless you nailed it wide open and finally it would shift hard into 2nd and the same to make it shift to 3rd and it wouldn't go into OD at all.
I made it home and parked it for a couple of years because I had already bought another truck and started driving it.
My buddy told me to stomp on the gas petal real hard about 10 times with the truck not running because it can get trash in the pressure cable, and that got it shifting again until today.
Now it's starting to downshift from 3rd to 2nd when I slow down to about 15mph and It's up-shifting late and hard again also but not as bad as the first time.
I tried the stomping method again but it didn't work this time.....any advice?
I googled (700r4 troubleshooting) and found this kit--anyone tried it?
http://transmissiontechnologies.com/...ve-kit-gm.aspx
Old 02-17-2011, 06:12 AM
SSedan64's Avatar
Link doesn't work.
Old 02-25-2011, 07:11 PM
i think you have sticking valves in the valve body, try a bottle of the lucas oil for transmissions and drive it around for a bit.
700R4 Questions srgould41 Transmission - Rearend 6 12-21-2009 08:18 AM
700r4 questions jeepguy48 Transmission - Rearend 6 11-10-2009 02:41 AM
700r4 troubleshooting eatonde Transmission - Rearend 4 07-30-2008 09:23 PM
700r4 questions BIG DIXIE Transmission - Rearend 3 01-11-2005 07:55 PM
700r4 questions marcus18 Transmission - Rearend 4 09-15-2003 07:50 AM
