700R4 TV cable help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2008, 11:41 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm making a custom installation of a 700R4, my question is how the TV cable should operate, is it like the TH350's that must be fully pulled when the carb's is at WOT and fully released when at idle? I heard that if wrong it will toast the tranny.
thanks.
Augusto.
Old 01-21-2008, 11:53 AM
wildman1932's Avatar
Dave's hot Rod Shop
Yep!!! We like Lokar brackets. They have not give us much trouble. Your adjustment is correct. It is the leverage that gets tricky. If not correct, it will make toast out of the clutches.
Old 01-21-2008, 02:45 PM
justold's Avatar
Wildman hit it rite on the head .The cable must be fully extended @ WOT and at its fully retracted position at closed throttle ,on a 350 the cable is a detent cable pretty much used for forced down shift .On the 700r4 it is regulating oil pressure in relation to throttle position {engine load}and if it is in the wrong place at the wrong time to often bad things happen ,that's the reason you don't adjust the cable to change shift points .
Old 01-22-2008, 07:49 PM
Augusto's Avatar
should the leverage be made directly progressive? meaning that at the throttle's mid position (45 degrees plate opening) the cable should be in the exact middle of it's travel range and so on?
Augusto.
Old 01-22-2008, 08:12 PM
Crosley's Avatar
Wiki Edits: 1659
view this PAGE
has photos , diagrams.... may help some ?
Old 01-23-2008, 01:05 AM
Augusto's Avatar
Tony,
thanks a lot, there is absolutelly all the info I needed and more, specially the pics about modifying the q-jet, that's exactly what I needed, thanks again.
Augusto.
Old 01-23-2008, 01:39 AM
700 trans tv
thanks.
Augusto.
The cable is same as a 350 almost. Yes the adjustment is the same.
Old 01-23-2008, 01:56 AM
Originally Posted by Crosley
view this PAGE
Nice info. Ill add to my other stuff
Old 01-23-2008, 05:22 AM
Crosley's Avatar
Wiki Edits: 1659
Same basic adjustment as a t-350 for the WOT point... A t-350 cable often had slack with the throttle closed. A 700 cable can not have slack at idle.
Need help adjusting 700r4 tv cable 85irocss Transmission - Rearend 5 06-18-2002 10:40 AM
