700r4 TV exhaust/failsafe ball ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 10:14 PM
blacklabzeke's Avatar
I am working on a 1988 700r4 and have a question about the TV exh. ball or failsafe ball. I have read this ball is left out in many rebuilds. Are there any advantages or disadvantages to removing it? Can it create problems adjusting the tv cable ?
THANKS
Old 12-12-2007, 05:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
THANKS
1. leave it out......
2. With a worn TV inner valve... the check ball may create a 'false fail safe' IF the fluid can not bypass the fail safe ball fast enough.
3. no difference in adjusting the setup of the TV cable
