Well I think I found the problem and I see no way of correcting it short of buying another TV cable. My current cable which I paid a premium for made by T-otal C-rap I-ncorporated appears to have a shallow limiter in the transmission end of the sheath which the cable linkage and hook from the trans bottom out on 1/4" shy of full engagement. There is no way I can see to correct the problem other than replacing the cable or hacking up my plunger rid linkage which I do not want to do.
![]() Here's what I'm talking about. That limiter in the sheath is inly 2.5" deep. I need 3" to fully engage throttle valve. We'll see what TCI has to say tomorrow. |
So the Linkage Rod is hitting in the Cable sheath?
If the TV Cable is adjusted correctly and that is happening, this part would help >> http://www.sonnax.com/system/announcement/77872-01.pdf Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts Or a new TV Cable. Bowtie Overdrives | TV Made EZ SUBJECT: 700R4 Throttle Valve Cable Adjustments Do you have the correct TV Cable bracketry? What type/brand Carb or Throttle Body do you have? |
If I remember correctly, I was thinking the end of the plunger should be flush when throttle is wide open.
This is why it's best to open up the trans and visually check plunge when setting up a new TV cable. I could have burnt it up, because everything else checked out. I'll do some calling around and see if I can't find an answer. Any other opinions are surely appreciated. Thanks! |
Does anyone have specs on that sonnax TV link rod. The one in my trans is 3.4" long. If the sonnax one is 3" or less it should work for me. |
I don't know the short TV Link specs, Sonnax may be able to tell you.
Do you have the TV geometry corrector Bracket for your Edelbrock carb? Summit Racing® Throttle Valve Correctors SUM-700203 - SummitRacing.com This corrects cable pull & Line pressure rise. Mounted Pic >> http://transmissioncenter.net/Setup.jpg |
Yes I have the corrector. Nothing on the carb end will change the limitations of the trans end cable sheath internal stop. I called up tech support at bowtie overdrives yesterday and had them take some specs from thier off the shelf TV cables and what we found was that in fact the TCI unit limits the amount of cable travel on the trans end causing it to bind. The distance from end of cable to internal limiter on the TCI is 2 1/2", and about 1/4" too shallow for wide open throttle with the stock TV link. Bowtie OD's measured one of their universals and it has a 2 7/8" measurement to internal stop. The factory GM unit has 3 1/4" to internal stop. So you're results may vary but the measurements don't lie. I even called TCI and had them measure another one of their units and it was the same as mine which rules out a mfg defect in the one I have. My advice is to stay away from the TCI cable. If you are not able to drop the pan or check line pressure a person would never know what was happening.
I wonder what brand the TCI cable is, I'm sure it's just a rebranded/repackaged cable?
Good Info to know to stay away tho'. I haven't had much luck with anything I've used from TCI.
| Well, I am going to take the plunge and rebuild my C4-Parts Advice Please | coda618 | Transmission - Rearend | 1 | 07-10-2009 12:17 PM |
| th 350shifting concern | r-mallis | Transmission - Rearend | 1 | 12-14-2006 07:28 PM |
| Looking to take the Plunge | Kwasyd | Introduce Yourself | 5 | 09-08-2006 09:41 PM |
| I Am Taking The Plunge!!!!!!! | Higirl | Hotrodding Basics | 16 | 08-16-2006 03:54 PM |
| Growing Concern | kitkar | Hotrodders' Lounge | 9 | 02-24-2003 12:45 PM |
