700r4 tv plunger gap (between lever and plunger) - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 06:57 PM
I know there's hundreds of posts on this subject but I couldn't find my situation.
this is on a 1984 Chevy pickup with the 6.2 diesel.
what I know:
all stock
correct geometry at the throttle linkage
set at WOT correctly at the throttle
correct TV cable length
no kinks, nothing bent
TV spring=1.94"
My problem is that I have about a 3/8 inch gap between the plunger and the TV lever. there are 3 rings showing on the plunger, and when I slide the plunger out to the lever, there are 5 rings showing.
!s this normal to have only 3 rings showing with no pressure on the plunger
Really confused!
Thanks for your responses!
could the spring be too short or maybe the TV valve itself be stuck
Old 01-28-2011, 07:27 PM
Crosley's Avatar
Wiki Edits: 1659
when the trans is operating, the plunger is pushed out by oil pressure
The linkage arm should just touch the plunger when the TV cable is at full throttle close and the valve body plunger fully extended
Old 01-29-2011, 09:03 AM
Thanks!!! "problem" solved!!!
700r4 shift lever problem kbyounger Transmission - Rearend 1 05-02-2008 06:04 PM
Booster plunger-How much movement? marks914 Suspension - Brakes - Steering 0 12-28-2007 03:38 PM
700R4 plunger 1chevelle Transmission - Rearend 2 11-14-2007 06:45 AM
lifter plunger vpoirier Engine 5 04-03-2005 06:57 PM
700r4 TV plunger spring AngliaBob Transmission - Rearend 3 01-30-2005 08:17 AM
