700R4 TV throttle lever and plunger problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 09:39 PM
Hey I just got done rebuilding and installing a 700R4 into a friends 72 chevy truck. The truck has an Edelbrock carb on it. This was a swap from an SM465 4 speed manual to the 700R4. We used a B&M fully adjustable TV cable, B&M Megashifter, And a Monster Transmissions rebuild kit. I am having a couple problems with the TV cable among other things. I have been doing research upon research and can't come across anyone else that has had this problem.... When I try to adjust the cable to where the throttle lever and the plunger are flush with the TV bushing the lever gets stuck. Which in turn causes the plunger to get stuck. I can get it to adjust to where the plunger is about 3/8 inch out of the plunger at WOT but if I try to go any further it all gets stuck. Also I don't know if its related or not but if we put the tranny into drive it doesn't do anything. It works in P R N 3 2 and 1 but it doesnt do anything in drive. My friend is itching to get his truck back but I don't want to give it back to him till I get this TV issue figured out so he doesn't destroy his transmission in 20 feet. Thank you for any help yall can give me
Old 04-29-2011, 10:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sounds like the TV plunger has a burr on it.
the 'no forward movement' in "D" , yet the trans does engage in 3 2 1 ... you have the forward sprag in backwards, in my opinion
Old 04-29-2011, 10:32 PM
Well the thing with the TV is that the plunger itself doesn't stick. The lever sticks. I have the pan off and when the lever gets stuck I can still move the plunger. And could the no drive thing be just not enough fluid yet? I really REALLY hope its not the forward sprag. I am positive I got everything put together correctly.
Old 04-30-2011, 07:49 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
then the linkage has a burr or is bent or the cable is a probleme?
why would the trans be low on fluid if you are testing gears? fluid level at proper height is the first item checked. Unless the fluid level is way low, I doubt that is the problem of engagement
Old 04-30-2011, 03:59 PM
I'll check the lever. It was a little low on fluid cause we were still adding fluid and going through the gears to make sure fluid was getting where it needed to go throughout the transmission.
Old 05-02-2011, 12:30 PM
So just another quick question, Will it hurt the transmission to drive it if I did put the forward sprag in backwards?
700r4 tv plunger gap (between lever and plunger) derek112 Transmission - Rearend 2 01-29-2011 10:03 AM
700r4 shift lever problem kbyounger Transmission - Rearend 1 05-02-2008 07:04 PM
700R4 plunger 1chevelle Transmission - Rearend 2 11-14-2007 07:45 AM
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 05:29 PM
700r4 TV plunger spring AngliaBob Transmission - Rearend 3 01-30-2005 09:17 AM
