700R4 unusual problem? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-25-2011, 05:16 PM
LATECH's Avatar
Last journal entry: New Gas Tank
If you have burnt 2 transmissions so far you might check to be sure the TV cable/ throttle linkage geometry is correct.That is pretty critical, there is a link on the website for the 700 r4 raptor that you have.
Immediate damage can result if not hooked up, or hooked up incorrectly.
Thought it was worth the mention.
  #17 (permalink)
Old 11-25-2011, 05:29 PM
TV cable is installed and setup properly. Dadwrench, the Jeep is sealed but is not insulated so for sure you here every rock I kick up. I figured to record at night so as to give no visual effects. You don't here the noise on and off the gas and the hard shift from 2nd to 3rd in those videos?? Yes, the transmission shifts fine, but that noise make me crzy.. guess I need to keep the music loud huh>>
  #18 (permalink)
Old 11-25-2011, 05:43 PM
Or put an anti clunk spring in it....or dyna mat the floorboard.
  #19 (permalink)
Old 11-25-2011, 05:58 PM
Ya I am looking into this anti clunk spring when I go back to NY for the holidays. Dyna mat would not block out this noise. its VERY loud.. but I do have a serious sound system so that will have to do.. poor neighbors though..
Unusual SBC timing problem 85GMCguy Engine 13 08-06-2010 05:48 AM
Unusual Vehicle Gauge Problem. M&M CUSTOM Electrical 4 08-06-2008 05:32 PM
Unusual S-10 T-5? Cosmo Transmission - Rearend 14 02-10-2007 07:02 AM
unusual cooling problem copndoc3 Engine 17 12-17-2006 11:02 PM
700r4 problem Chuckusp45 Transmission - Rearend 3 08-18-2004 10:35 PM
