700r4 upshift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2007, 01:47 PM
700r4 upshift
hi all i have just put a 1990 700r4 in my 42 cornbinder, and it won't upshift. i believe i've set the tv cable correctly and made a throttle shaft correction according to tci bulletin board. i have a strong 1st gear but it doesn't upshift . i havn't run it up over 3500 rpm cause i didn't know if i would hurt anything else. the engine torque was designed from 1200 to 4700 rpm. i have looked at the governor and everything is free in it and the gear is good. does anyone have any ideas or reasons it won't upshift.
Thanks tuk
Old 08-12-2007, 01:51 PM
add on
sorry i forgot to mention the 4 wire plug on the tranny. as i read post i get the indication A B D terminals are not always the same function is that so.
please help desperate rod run in spokane this comming weekend
thanks tuk
Old 08-12-2007, 06:10 PM
Crosley's Avatar
Wiki Edits: 1659
IF all is good with the governor;
TV cable minimum setting may not be correct.... If the minimum cable point is not pulled enough the trans can go into fail safe mode IF the check ball is in place. Some builders remove this check ball located near the inner TV linkage
Do you have full TV cable pull at WOT?
Could be stuck shift valves
700r4 Upshift Problems Mick Ferl Interior 5 10-13-2004 08:50 PM
No 1-2 Upshift on 700r4.. Bravada 442 Transmission - Rearend 2 07-22-2004 01:07 PM
700R4 late 1-2 upshift rearden Transmission - Rearend 6 06-13-2004 09:30 AM
700r4 no light throttle upshift 80SomethingZ28 Transmission - Rearend 3 02-06-2004 08:11 PM
700r4 upshift probs MDFbodies Transmission - Rearend 2 07-26-2003 10:24 PM
