700r4 when floored it wont shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2012, 09:04 PM
so i had a rebuilt 700r4 installed in my 71 camaro 454. it shifts hard into 1st unless i press the gas pedal just right it shifts smooth. but when im cuzing and punch it, it will not shift out of 2nd or if in 3rd into 4th. so it is sticking?? i drive in 2nd punch it and no shift into 3rd it red lines and starts to smell like tranny fulid bad no leaks and if i let out it shifts into 3rd very weird its like i have a manual tranny and when letting go of the gas for a second it shifts and i can get back into it and it goes but until i let out of the gas a bit it stays in that gear. works fine under normal driving shifts though all gears. any help sticky gears i guess
Old 04-26-2012, 12:22 PM
jayseasBlue56's Avatar
It sounds like or could be the TV cable is inproperly adjusted.Don't drive it this way it will burn the tranny up in time.
Old 04-26-2012, 03:34 PM
Rhansen's Avatar
Footbraker
^^ agreed, sounds like TV cable is too tight at WOT
Old 12-12-2012, 01:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Correct adjustment of the TV cable is uber important. The geometry of the carb linkage also need to be correct. Info/links here.
Good luck.
Old 12-12-2012, 10:54 PM
Park it until you can get it adjusted properly. Hopefully it's not already too late. Did your builder not warn you about proper setup?
Old 12-17-2012, 02:41 PM
Any updates did you figure out what was causing it .I've had the same issue for some time
700r4 wont shift into 3rd. dms Transmission - Rearend 3 08-26-2011 08:04 PM
700r4 trans that wont shift to dr or od emyers Transmission - Rearend 3 03-19-2011 04:51 PM
700r4 wont downshift into 1st when floored KnightRider84TA Transmission - Rearend 8 08-04-2009 05:33 PM
700r4 wont shift out of first gear illegal regal Transmission - Rearend 33 02-08-2009 07:32 AM
700r4 wont shift into 3rd BIG DIXIE Transmission - Rearend 1 01-12-2005 07:04 PM
