Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Why are the TCI manual valve body instructions so lousy?
Old 05-18-2006, 08:46 AM
eliotmansfield eliotmansfield is offline
TCI supplies a custom plate, it's red anodized.
The lack of pressure is your problem, on the test port for a particular gear, it should be the same as line pressure (i.e. well over 200psi) when that gear is selected.
You saying that you used your original separator plate?
The kit contents states "1 Separator Plate"
