700r4 , will it hold up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 12:59 PM
70CHEVYSHORTY's Avatar
New Age Classic
Last journal entry: Seat
Will my 700r4 in my chevy c10 hold up?
sbc 355 stock crank 9.1 c/r with aluminum heads.Combustion Chamber: 64cc
Intake Runner: 190cc
Intake Valve: 2.02"
Exhaust Valve: 1.60
a lunait hydralic cam 276 duration 504 lift 2200-6400 range and 1.6 rockers
1 7/8 tube headers wit 2.5 collector and a demond 750 cfm carb. Thanks for your time.
Old 10-27-2009, 07:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a well built 700r4 / 4L60 trans will have not problems with that mild engine.
The carb is too large CFM though.
Old 10-27-2009, 07:50 PM
302 Z28's Avatar
Very common mistake.
Vince
Old 10-28-2009, 07:57 AM
New Age Classic
Carb
The carb is to large but for the price $50 i couldn't pass it up leaves me room for growth i am actual planning on putting on a weiand 177 blower come spring then it might be on the small side.
Old 10-28-2009, 06:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
with that small blower the carb would be OK
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
V6 or V8 700R4 swap? cacsmret Transmission - Rearend 4 05-05-2006 09:28 PM
2wd to 4x4 700r4 QUINTANA64 Transmission - Rearend 7 04-05-2006 05:20 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700R4 vs. 2004R 81ElCaminoGuy Transmission - Rearend 2 08-21-2002 01:10 AM
