700r4 will not upshift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 01:31 PM
700r4
staying in first how do i fix
Old 02-24-2012, 03:02 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
check that the T.V.cable is hooked up and adjusted right...check the governor...pull the valve body and look for a stuck T.V. valve or 1-2 shift valve..check back with the results.
Old 02-24-2012, 05:05 PM
700r4 wont shift out of first help
has reverse just wont go out of first could it be tv cable? if so looks loose where it connects to motor. do i lube up where it connects to transmission? anybody know what to do?
Old 02-24-2012, 05:09 PM
wont shift out of first what do i do
Old 02-24-2012, 05:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title. We do not "Help" in thread titles here. Please place information in the thread title so the members have an idea what your problem is.
Please keep your questions in one thread on the same subject.
Old 02-24-2012, 06:23 PM
Prof. T. Soggmeyer's Avatar
Plan B
Your throttle valve (TV) cable at idle should be all the way in with no slack, and at wide open throttle (WOT) should be all the way out. If it is not like this you will have many issues.
Brad...
700r4 sometimes no upshift from first frankstile Introduce Yourself 1 03-16-2008 08:52 AM
700r4 upshift crustyone Transmission - Rearend 2 08-12-2007 06:10 PM
700r4 No 1st-2nd Upshift 30chevy Transmission - Rearend 3 02-06-2007 10:55 AM
No 1-2 Upshift on 700r4.. Bravada 442 Transmission - Rearend 2 07-22-2004 01:07 PM
700r4 upshift probs MDFbodies Transmission - Rearend 2 07-26-2003 10:24 PM
