You describe a trans that ''thinks'' the TV is fully pulled. At engine idle the pressure of the trans should raise if the TV is pulled. If you see little pressure change with NO engine RPM increase as the TV cable is pulled this would indicate a stuck TV inner valve. This method of test would show a weak pump if the pressure does not increase to the same 150 psi you mention with throttle application in park
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Ed |
Hello Crosley,
Here's a link to a video of the test that you asked me to perform. At idle, the pressure is now sitting at 130 psi. It holds pretty steady as the TV cable is pulled put. What's odd is that when the cable is released, the pressure momentarily drops to 80 psi then returns to 130 psi. http://www.youtube.com/watch?v=OB0IlboxKts If I do need to clean/unstick the TV valve, what parts will I need other than a pan gasket? Thanks, Ed |
Could it be a worn / broken gear on the governor?
Sounds like a worn TV inner valve and bore. The oil is bypassing the valve and boosting the line oil. The trans will then ''think'' the trottle is WOT and shift late. Some tiomes a TransGo TV valve setup will fix this problem. Other fix is the ream out for over size valve from Sonnax... Next option is replacement valve body. That is my best guess at the moment
| 700R4 won't shift @ WOT | Typhoon | Transmission - Rearend | 6 | 05-18-2009 06:22 AM |
| 700R4 won't shift | tombtomb | Transmission - Rearend | 5 | 06-23-2008 08:34 PM |
| 700R4 won't shift out of first | Tim in MD | Transmission - Rearend | 15 | 11-29-2007 08:00 PM |
| 700r4 no shift!! | MonteCarloDave | Transmission - Rearend | 2 | 07-19-2005 06:05 PM |
| What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 | AngliaBob | Transmission - Rearend | 3 | 04-23-2005 11:25 PM |
