700r4 wiring?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 04:18 PM
75GMCman's Avatar
700r4 wiring??
Hi everyone! Last week I got my hands on a 700r4 (out of a 89 wrangler) for my 75 gmc. I haven't bought a book for it yet. I looked in the knowledge and found the "Wiring a Lockup-Converter Pressure Switch." Mine has that little silver thing where all but one wires go too! How can I make this work in my truck? The same as the article?? I don't want to have the lockup on a toggle switch, too much to think about when driving! What I want to do with this truck is drive it around and drag race it, and have a B&M pro ratchet shifter too. The tranny I'm swapping out is a sm465.
Thanks for your help!!
Caleb
Name:	700r4 valve body.JPG
Old 01-20-2009, 04:28 PM
SSedan64's Avatar
Caleb
Sliver thing is Temp sensor,not needed. If trans gets hot it will cause the TC clutch to lock just like when the 4th gear pressure switch senses pressure.
12V from brake light switch to PinA on case should do it. 4or5Pin brake switch will disegage TCC when you depress pedal. Most don't use the vacuum switch, causes to much TCC cycling.
http://www.smokemup.com/tech/700r4.php
Old 01-20-2009, 04:45 PM
tnsmith10's Avatar
when will it rain???
another reason for the temp switch is also to prevent lockup from coming in while the trans is coming up on operating temp....
Old 01-21-2009, 09:49 AM
75GMCman's Avatar
I had in my head for wiring it up is hooking the solenoid to the brake switch then black from the solenoid to the pressure switch. How could I wire it with the temp senser or should I just leave it out?
Thanks!!
Caleb
Old 01-21-2009, 10:16 AM
tnsmith10's Avatar
you can leave it out if you want... i would go through the pressure switch (normally open) through the 4th gear port before the lockup solenoid. ive done several of these this way and it works great.
Old 01-21-2009, 10:37 AM
75GMCman's Avatar
thanks for the reply! If I hooked it up my way won't it work because when it goes into 4th won't it complete the circuit?
(tnsmith10) you can leave it out if you want... i would go through the pressure switch (normally open) through the 4th gear port before the lockup solenoid. ive done several of these this way and it works great.
Just so I understand this run the power from the brake switch to pressure switch, then to the solenoid and black wire hook it up to ground somewhere. Also Can I use the stock pressure switch?
Thanks!
Caleb
Old 01-21-2009, 10:44 AM
tnsmith10's Avatar
yes, i believe it should., this is just the way i do it. cause i only run 1 wire.. so its constant 12v all the time. and the switch being normally open wont know the difference till 4th comes in.
yes as long as its a normally open switch... an ohms test will tell you what typ of switch it is...
and you can just put an eyelet on the black wire off the solenoid to the valve body to use as a ground. leaves a simple 1 wire setup.
it'll come out of lockup either when you hit the brake, or when it drops out of 4th.
700R4 LockUp wiring diagram chevychase Transmission - Rearend 9 03-29-2016 06:54 PM
700r4 lockup internal wiring gearhead77 Transmission - Rearend 2 04-16-2008 07:14 AM
Need help wiring my 700r4 409guru Transmission - Rearend 3 01-21-2008 02:02 PM
Wiring switch for 700R4 dontnobetter Electrical 3 11-15-2006 12:26 AM
700r4 wiring questions murrsue Transmission - Rearend 4 02-04-2005 10:09 PM
