700R4 wiring blues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2013, 07:00 PM
700R4 wiring blues
I am in the process of building a, from the ground up hotrod, actually more of a warm stick as the motor is currently a stock 305. I first purchased a 4.3L with the attached 700R4 in deference to the gas prices, however got scared off and decided to go with what I know how to work on, a basic sbc. This is a completely non computer rod. I kept the 700R4 but have almost decided to sell it and go with a Turbo350 because I really do not know how to wire the thing up so that the overdrive ie, lock up converter will work as advertised! Any help would be appreciated. This is a low budget build for my grandson so cost is an issue, or I would have already just bought a T350. The tranny came out of a l992 blazer, has a 4 pin connector and electronic speed sensor, no speedo cable. I would also like to convert back to the cable speedometer. Is there a conversion kit for this.
Old 07-09-2013, 07:21 PM
jokerZ71's Avatar
Wrench Turner
I think so.Check Transgo.
Old 07-10-2013, 06:03 PM
LATECH's Avatar
PATC has info on how to and parts to do it.
http:// www.transmissioncenter.net
Look around and do some reading. Good place to go for parts and answers.
Fact is stranger than Fiction
700r4 wiring?? 75GMCman Transmission - Rearend 6 01-21-2009 10:44 AM
Need help wiring my 700r4 409guru Transmission - Rearend 3 01-21-2008 02:02 PM
700r4 blues fattys50 Transmission - Rearend 3 08-06-2006 08:37 PM
700R4 wiring? DirtyDoug Transmission - Rearend 9 12-30-2004 09:04 PM
the 700R4 blues turbotim23 Transmission - Rearend 4 01-03-2003 02:13 AM
