Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 won't engage in any gear
Old 04-27-2003, 06:06 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
obivously the pump is still functioning with pressure readings.
I would venture a guess that the drive splines of the turbine hub broke away inside the converter. This is a common failure of the 700 converter.
It is also possible the input shaft twisted out of the aluminum input drum or the drum broke where the input shaft presses in.
Hopefully you will receive some assistance from Bowtie.
[ April 27, 2003: Message edited by: Crosley ]</p>
